Old 01-02-2003, 11:32 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
The fellow that made my driveshaft told me that I should try to keep the angles on both u-joints approximately the same and that they should be no more than about 5 degrees each. He said that u-joints that work at 10 degrees or more cannot be expected to last very long. He also told me that a u-joint that operates at exactly 0 degrees will also wear out more quickly than normal since the needle bearings are not moving around and they will pit the surfaces where they touch.
I used a magnetic angle finder to adjust the angles to about 3 degrees. Of course that is at normal ride height. The actual angles will change up and down as the car is being driven and the live axle moves.
Wayne
Don't get caught dead, sitting on your seat belt.
