Have fitted my Tilton Pedal Box, overhung type to the top of my Footwell!
With getting the correct centers of the balance bar in relation to the Master cylinder(s) bore centerline, there is a lot of clearance between the clevis's and the spherical bearing housing from which the pedal comes off!
Point One: Tilton say to set the distance of the clevis's to 1/2" haven't any idea what that means? - as nothing anywhere is remotely like that if centers to avoid side load of Mastercylinders are anything to go by!
Point Two: With all this clearance, I wonder what happens if one circuit/cylinder fails then the clevis aint going to lock against the pedal spherical bearing housing to provide one circuit with some brakes?
Ant
