I run 10 on the rear and 8 on the front with BlueStreaks...8.00x15 rear and 6.00x15 front. The car is set fairly low to the ground with stiffer than stock springs. At full bounce when racing...I get tire rub on inner and outer finders at the rear...not from cornering...but from full suspension compression. I don't remember what the offset is, but it is slightly different from stock ERA....I have the full independent rear set-up and initially had some rubbing of the tire on the suspension during cornering...slight rework...no problem after that.
MF
