Thread: SB or BB
Old 01-05-2003, 09:00 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Small block based on of course a Chevy.
FALCONER V-12
HIGH PERFORMANCE PRODUCTION RACE ENGINE
SUPPLEMENTAL FACT SHEET
WEIGHTS & MEASURES
- 600 CID
- 522 LBS.
- 4.125” BORE
- 3.750” STROKE
- 23.5” WIDE; 23” HIGH; 36.5” LONG
(WIDTH FROM CRANKSHAFT CENER LINE)
(LENGTH TO FRONT ACCESSORY DRIVE PULLEY)
- ALUMINUM BLOCK & HEADS
PERFORMANCE
Running Race Gas:
- 1100 HP AT 6500-7000 RPM NORMALLY ASPIRATED
- 1200-1600 HP SUPERCHARGED OR TURBOCHARGED
PACKAGE
Each engine is dyno tested upon completion and
base price includes the following:
- ECU
- DRY SUMP
- INDEPENDENT RUNNER MANIFOLD
- DIRECT FIRE IGNITION
SUPERCHARGER OR TURBOCHARGER ADDITIONAL
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
