Old 01-06-2003, 08:18 PM
Terry Terry is offline
Jason.
You could change the ratio of the rockers to 1.72 instead of changing the cam. If I remember correctly it is about a .030 increase on the lift. Remember that if you go to any power adder you will need to upgrade your injectors. The stock 19lbs are just barely enough for a stock engine and let’s not forget the fuel pump.
Terry
Terry
