Mike,
Tommy is always running behind, like the rest of us. If Tommy has made the 4-point like we make ours, then I'm sure it will fit perfectly under the soft and hard top.
The trick is cutting the rear body at the proper location and angle to fit the pipes!
. If you want a source for grommets and rings to cover the cut outs, then contact Finish Line. Paula and Enzo have the best fitting trim rings to date. Not perfect mind you but close!
Question for you: Is your bar removable after the body is on?
DV
