Brent,
You didn't say what you are using the car for. If it is just a street cruiser then what you already have is probably OK. If you want to do some high rpm racing then perhaps a set of forged connecting rods might be a good idea. I have destroyed two good engines running open track, both because of rod failure. As far as cam choice, tell the cam grinder what you are planning to do and what components you are planning on using. They will recomend a cam grind to suit your needs.
Nice to see somebody doing something a little different.
Good luck with the build and keep it small.
Cranky
