Old 01-09-2003, 09:19 AM
Roscoe's Avatar
Roscoe Roscoe is offline
First off you Milodon pan should have two threaded ports, one for draining in the rear of the pan and another for the temp unit. Why doesn't the sender fit?
Second, make sure you get a billet block off and throw away the one you get with the remote kit. The block off is available from Canton, Pegasus Auto Racing and Racer Parts Wholesale. Also, if you are going to use a single remote then consider using the billet ones available from the sources I mentioned. No matter what you do stay away from that cheapo blockoff.
Roscoe
Roscoe
