Old 01-14-2003, 04:10 PM
WYT VNM's Avatar
WYT VNM WYT VNM is offline
Cobra Make, Engine: Unique 427; 428 Mid South Gear
Cool
Originally posted by Pete C
Dan,
26 psi front, 23 psi rear at most! Start there and check after first session. At 40 psi, you will be sliding all over the place.
Cheers, Pete
PS You are right the BFGs are dogs but good to learn on cuz you gotta have the right line and an easy touch. The good news is that the BFGs will give you more warning than the slicks which will hit and pass through the limit of adhesion with little or no warning. After you get some track time with the BFGs check out the Goodyear Cobra tires through Roger Kraus racing. http://www.rogerkrausracing.com/
Thanks Pete C. I went down 3 lbs. less than your recommended; still on ball bearings at Nashville. ***********Got Hoosiers Now
Dan Fowler
Knoxville, TN
