Old 01-15-2003, 12:42 PM
sexzsn8k sexzsn8k is offline
Cobra Make, Engine: ERA #624 (427 S/C), 428 PI
Default Studs for Rocker Stands
Paul, I also have the FE Max rockers and they should have sent you a set of studs with the rockers. They should be ARP, but if not, purchase a set of ARP's. If you read their (ARP) literature, they state to just seat the studs, hand tight, and then when doing the final torque, the stud and nut will turn together, giving an even torque setting. Just make sure that you use their lubricant on both sets of threads, the flat washer and the bottom of the nut.
If you want manners, drive something else....
COBRA's are ALL about EXCESS !
