Why not buy the 514 SVO and.....
Change the cam to an hydraulic roller? This willl cut HP to + ~ 550 and make maintenance easy. You could also have it balanced and blueprinted while you are at it. Compression is 9.8 to 1
Just keep in mind : They are "hot run" but there is no warranty.
If you want a custom built motor, the consensus here at CC is Southern automotive.. I hear good things about them and if I order a Ford performance motor in the future, they get my first consideration.
One last note:
With aluminum heads you can go to 10.5 to 1 with no pinging, on 91 octane.. this is just heresay, and also my experience with motorcycle motors.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
