Old 01-19-2003, 09:15 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
The intake isn't as big a concern on the 302 it's the placement of the oval air cleaner. All the ones I've used had to be cut and pasted. The base off the air cleaner needed to be offset to fit under the hood scoop. If you use the smaller oval type they will fit. It's just the fullsize ones I have to change. I normally run a manifold like the Edelbrock Performer RPM on the 302's. If you use the dropped mounts you may even get by with a taller one.
Don
