Old 01-20-2003, 07:37 AM
chuckbrandt's Avatar
chuckbrandt chuckbrandt is offline
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default Testing for Vacume Leaks
When assembling a new engine or working on a running engine with problems, is there a way to effectively test for vacume leaks on an assembled engine. Could you close the valves and block off the carb flange and use a leakdown tester? If so how would that work? Is it reasonable to expect it to hold a vacume before it's run or does it have to go through some heating cooling cycles first?
Thanks, Chuck
