Old 01-20-2003, 08:58 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
The newer mounts from Classic use the Mustang GT isolators. It drops the engine by 3/4" which gives a little more hood clearance. If you are using the older style mounts from Ford you would need to buy new frame mounts and isolators. The air cleaner may fit under the hood with the lower mounts. I don't have a template for the air cleaner. I just modify it as needed.
Don
