Old 01-21-2003, 09:31 AM
LeonardU LeonardU is offline
Cobra Make, Engine: Contemporary, 427 SO
Question Radius rod setup
I have a Contemporary Cobra and would like to know exactly how the radius rods work and how they are set up. If the rods attach to the rear, don't they hit the gas tank? If you have to make a bracket to clear the gas tank, doesn't the bracket look ugly when the car is viewed from the rear? I would install one using heim joints at each end. Could you sent inform and pictures if possible to my new email at Leonardu2@sbcglobal.net.
I installed Wilwood brakes on my Contemporary with Jag front end and spent a lot of time researching the topic. I looked at all the Jag kits available and was unhappy with the quality and price. I was able to use a Wilwood stock disc and caliper. I fabricated a hat and caliper bracket. The design was time consuming, but the assembly was beautiful and it works well. When it was installed it was spot on. The only problem was that the Wilwood discs were not true. You need to have the Wilwood discs checked to determine if they are true before you install them. I would be happy to share my drawings and dimensions with anyone that needs help.
Thanks,
Leonard
