Assuming you're using 157 tooth flywheel.
Starter. I've gotten great service so far from Powermaster starter. Summit. $159 or 169. It's in the catalog.
Fuel pump. Used Holley street fuel pump with Edelbrock bottom inlet conversion kit. Fuel in, comes in under the pump. Fuel out to carb is normal, except on the wrong side of the engine.
Carb. If I had it to do over, and didn't use EFI, would go with Demon 650 (driving mostly under 3000 RPM), or Demon 750 (a lot of driving over 3000 RPM).
