Old 01-26-2003, 01:13 PM
JoeLafives JoeLafives is offline
Cobra Make, Engine: Unique 289 FIA,302 Crate,Holley 600cfm
Default tie rod ends for an MGB front end.
Does anyone have any really good hints on how to tighten the lock nuts on the tie rod ends for an MGB front end. As you may be aware, the tie rod ends are a snug fit into the steering control arm on each of the front wheels. The thing is that the "stud" is not "locked down" on the tie rod so when you attempt to tighten the lock nut the "stud" turns as well.
Best
Scott
HANDLE WITH EXTREME CARE: This product contains minute electrically charged particles moving at velocities in excess of five hundred million miles per hour
