hey Mike,
Mike I run a 351w for circle track, I always remove this hose for better cooling, (allows all fluid through rad.) We run 28 to 32lb. caps. It's just one more hose we don't have to worry about blowing. it is also a excellant idea to drill two #30 drill bit holes on each side of the thermostat, It should run 8 to12 degrees cooler than current thermo reading. and also let the air out of the system.
Dave
