Originally posted by J.L. Nanson
To Cobra owners who have gone to the dark side, I need your A9L EEC! Please if you have some old EFI stuff, I'm looking for 30lbs injectors ( jets for the dark side peoples)and a A9L EEC ( the same as a bunch of jets and an extended knowlege of which jets to use on the dark side) More on the reason I need this stuff later. Please email me at azcobra98@earthlink.net Thanks Carb Dudes
Would agree that 30lb injectors are on the large size, but don't know your project, can cause problems with idling as you'll be shooting a lot of fuel at low rpms even if the large size is needed in the upper rpm range for your motor. You can buy 8 packs from FRPP for $200 or so which is probably a reasonable price. You can also source the EEC box from them as well and the harness(es).
