I mean quick.. in fact Vern has them wired so the fan is ALWAYS on when the ignition is on.. to turn it off at the present time, one only has to pull the spade fuse.. I am going to wire in a manual cutoff switch later tho.
I need to actually time her temps from a cold start, and get back to you guys, plus, the inspection will also be done, with the TO bearing, hopefully next week.
No way I can drive in this downpour anywho
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
