Old 02-03-2003, 04:28 PM
George Snyder's Avatar
George Snyder George Snyder is offline
ST,
I can't see anyway I can get a 14" assembly on. I viewed your pic gallery, but remember you have a 427, not a smaller 302. It also looks as if a drop base would make it worse, as it would hit the dist.
NROTUXIN,
You are correct on the 1966 being 6'. I stand corrected. K&N will build about any size air cleaner you may want, but the cost would be unsudstantiated.
Mr Fix it,
I can believe what you said. If you spin that 396 at 6k you need 114 minimum and at best you were at 131. Remember this is one case were more is better.
There are many options that could be used, not limited to a custom air induction system. I am selling myself on the X-Stream Unit as the cheapest choice. It should do very well in this application as far as a functional air scoop delivering a direct flow onto the top of the Filter lid. The cost isn't too high either.
