I had the same problem after new r4 front brake pads. If there is air in the system, the pedal will pump up. I chased enough things around and then finally checked the pads in front. i pad was glazed. I later called porterfield and found out that I had 1 pad that was a different compound then the other 3 pads. It would stop straight until the pads warmed up and then a left turn. Check the pads.Good luck, scott.
