Thread: Break in ?
Old 02-04-2003, 12:46 PM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
I suspect, although I am prepared to be proven wrong, that this is a "precaution too far".
Whilst you may indeed get minor pieces of metallic debris in the oil during break-in, it will have gone through the oil pump before it gets to the cooler (assuming cooler is "seeing" unfiltered oil - depends on the configuration).
This means it would be minced pretty fine in any case, so unlikely to get "hung up" in, or block, the cooler.
If you have any metallic particles large enough to cause problems after the filter, then you are in a world of hurt anyway, junk oil cooler the least of your problems.
I would, personally, think twice before introducing an additional restriction to flow, in the shape of a screen or filter before the oil cooler.
I would just change oil and filter regularly during break in.
Of course, race practice, where engine blowups ae more "accepted" or "expected", is different.
Just MHO.
Wilf
