Old 02-05-2003, 08:53 PM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
cecoen,
Since you have MGB suspension components you may have a damper problem. If I recall correctly, the MGB used lever dampers as the upper a-arm. If this unit has gone bad, you will experience the behaviour you have stated.
You know, if the damper is bad, you will have less bump resistance and therefore more weight transfer to that corner.
Might be worth looking at.
Best regards,
Richard Hudgins
