Rick, thanks for clarifying my misunderstanding regarding racing Richmond racing transmissions. There may be a 5-speed racing model in my future!
About 99 percent of my driving has been under-part throttle conditions, and the information about potential for main shaft separation actually explains something to me. Since I live in the San Jose metropolitan area, there aren't any open roads where I can safely test the car under full throttle near home. So, at part throttle, the transmission is a dream and can be shifted extremely fast, especially after initial break-in ..but at full throttle...hmmm. I have experienced two mis-shifts from 1st to second, under full throttle, while trying to speed shift. Those may be the only two times I have tried putting the pedal to the floor AND shifting as fast as possible (maybe without full clutch disengagement). I had previously chalked those events to user error. But now it seems like I may have tried to shift my transmission TOO fast due to the transmission shafts. It'll be interesting to see how fast I will be able to shift without mis-shifting. If I find shifting is too truck-like for my taste, a racing version may be in my purchase plans.
Regarding gear ratios, I'm running a 3.08 rear end and a 3.27 first gear. I have been thinking about going to a 3.40 rear end ratio, since my 6th gear is barely useable unless I'm going 85 MPH. I've calculated that at redline, my car is geared to go 212 MPH. I doubt 400 HP and 400 ft-lbs could push that much air, and predict a true top speed quite a bit lower. But, the 3.40 would make 1st too low, as I think 1st is too low as it is. I would have to relegate 1st for burn-outs only, and use 2nd thru 6th for everything else. I'm not a big tire spinner, so the new transmission might be coming sooner than later.
To prepare for then, are there any recommendations for an appropriate 1st gear ratio?
Daren Gee
Daren Gee
VSE #22
