Thread: Paging Naja !
Old 02-09-2003, 08:53 PM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Dell makes a nice tower, dual pentium IV, CD Burner, DVD, and a floppy. If you can get one of those 17 " flat screens tucked in under the dash over the tunnel, and run some wire to the trunk you should be able to mount that thing in the trunk right next to the amps. Be careful with magnetic fields. I think it effects the SDRAM negatively.
If you could put a small hub, and use it as a server than you can run CAT-5 cable to the cockpit,. Cat-5 is less bulky, and this set up would also allow you to have a small LAN in your car to hook up your laptop if you had to.
Just a thought!
TURK
OBAMA IN in 2012
