Originally posted by dscott
Tony, nobody noticed, no distributor! The Tec 3 computer uses a crank trigger and coil packs for firing. I had to machine an oil pump drive held in the normal place. You can see the top of it if you look close. By the way DV I machined that part on my new Smithy mill (ha, ha,)!
Don
Don, I can't see for sure how you've done the dist plug, so could you please let me know if your crank trigger wheel shows sync AND reference, or are you using something similar to the Explorer DIS spout to show the cam sync?
