  #33 (permalink)
Old 02-11-2003, 07:21 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
750hp, the Tec 3 computer can trigger from either the crank or the crank and cam. All I needed was an oil pump drive from the cam. Tony's system uses the crank trigger and fires 2 cylinders at a time. As an example cylinder 1 & 6 fire at the same time. Since they are 90 degrees apart #1 fires on compression and # 6 fires on exhaust. The system works great and eliminates the need for the cam trigger. All I did was take a distributor and machine it down to block level, cut the shaft to the proper length and installed a brass plug at the top.
Don
