Old 02-13-2003, 08:15 PM
Terry Terry is offline
Jason,
You have to work from the top down if you want to make more power. As you probably already know your engine is an air pump. The more air and fuel that you get into it the more HP it will make. The 19# injectors are just adequate for the stock engine, you will need to increase the size if you intend on making more power. This means that you will need to change the calibration on the Mass Air as well. It is very difficult to change just one item on an injected engine they all work together. Without a good set of heads, intake, throttle body, mass air, injectors and either changing the ratio of the rockers or a cam, you will not be able to feed the stroker. On the other hand a stock short block with all of these items will make decent HP.
If your on a budget, try a site called the corral. This a site that people sell used parts on and you can save a good amount of money.
Just my $.02
Terry
Terry
