Whats a trigger wire? The only wires going to the relay are the accessory wire 112, which is hot (12V) the ground, the ballast resistor and elec choke (128) which I'm not using and the fuel pump relay to fuel pump fuse wire (131) which gets no power when I turn the key. So I have to connect a ballast resistor just for this relay?
Thanks
indy cobra 95 mustang GT 5.0
