If you are using the standard wiring from Classic you don't need anything more. The power wire for the pump that runs through the rear harness does have a relay circuit. All you need to do is turn on the ignition and you will have power to the pump wire. Are you sure you have a fuse in the fuse block for the fuel pump?
Don
