Old 02-14-2003, 02:36 PM
wicked fast's Avatar
wicked fast wicked fast is offline
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Thumbs up Yup...
It's real easy.
De-solder your tank with a propane torch that
use use to solder copper tubing with.
Cut down the neck as needed,
cut the rivets that hold the brackets together.
Cut the brackets to our desired height.
Turn the tank and reassemble.
I had a radiator shop resolder the tank and
pressure check it.
Check out the picture in my gallery.
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
