I've got the old plain jane 3550,put in my car in 94 or 95,has 16,000 miles and I go to the drag strip 3 or 4 times a year,so far,I've chainged the fluid in the trans. once,no problems since day one and shifts smooth as silk..Running a 351-W,approx. 350 hp at the flywheel. A buddy has the same trans in his 90 Mustang installed in 1993, behind a 377 stroker putting out 415 hp. It has seen a ton of drag strip passes probably over 200 with the same results as I've had....Can not say one bad thing about mine or his.... Back then,I do not even think they had come out with the TKO yet,only the standard version avaliable then....Love them 5-speeds....
David
DAVID GAGNARD
