Aluminum small block??
Do we have a aluminum small block guru in the house? I would like to put an aluminum blocked motor in my 289 FIA. My research has led me to the 302 and 351 Ford Motorsports blocks. I haven't been able to find any specific info on the blocks other than price($3,800 via the net). Are there other aluminum SBF's out there? Is the FMS AL SB a good one? In the 450hp range, which heads? Which intake(assuming one 4 barrel)? Which carb? Which crank, rods, pistons, camshaft?
The car will see mostly street duty with limited strip time and possibly track time if I can learn to drive.
Will we're at it, Toploader or TKO II?
Thanks, Jim
