Thread: Stall speed
Old 02-19-2003, 06:15 AM
boxhead's Avatar
boxhead boxhead is offline
Listen to Excaliber, with that type of ratio in the final drive you really would be better of with a lower stall speed especially if you will use it for street driveing mainly
Also with a diff ratio like yours and a hi stall speed you will be creating alot of heat in the trans, so make sure you fit a good quality cooler with a hi flow rate.
Also the lower stall speed will improve the fuel economy.
Cruising in 5th
