Old 02-19-2003, 05:10 PM
frankym frankym is offline
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
Smile
curioius as what you mean that they don't fit, do you mean the bolt pattern doesn't fit or that the offset and tire combination doesn't fit properly in the wheel wells? I presume it's the latter, if so, what tires and dimensional back spacing were you using prior to the trigos and is your fit problem too deep into the wheel well or set out beyong the fender lip? you may be able to salvage the setup but first explain the situation more clearly and perhaps your frustration will have a happy ending
