Sparks,
I had almost the same thing happen to My Car the 1st time out.
Ended up it was the Holley Fuel Pump was assembled wrong. Pressure by-pass.
If it is the floats, it is easy to see fuel level thru site glasses. The gas should be close to the middle in the glasses.
If the are too high the fuel will be dumping into the engine at idle. If too low the engine will die at higher RPMS, but will recover after you let off the gas and the fuel bowps have time to recover.
I can not really comment on if it could be the coil pick-up.
Just a thought! I would guess fuel. Pump or floats.
George
