Old 02-22-2003, 12:43 PM
JAM1775 JAM1775 is offline
Cobra Make, Engine: SPF 974
I am not sure what you mean by no heat opening but if you are referring to the hot air heat crossover in the middle of the head it should be blocked. The 1262 blocks this opening because it is only used to heat up the stock motor faster. But in Hi-Po applications that opening does nothing but keep your intake hotter...don't need that.
