Old 02-22-2003, 03:38 PM
sparks's Avatar
sparks sparks is offline
Cobra Make, Engine: #1459 w/460(sold)New(used),spf w/427s.o.(sold)
Aumoore, Fuel pump is mounted under tank, As far as venting ? when I open gas cap to put gas in I hear a sound like the tank itself is full of pressure(escaping presure?) The temp was about 50 outside and fans did not even kick in yet.
Mike I,
Have the msd ign. with taylor wires. Everthing is routed cleanly. Only backfired on deceration 1 or 2 times. Raised float levels a bit and it helped alittle. Even took rev. limiter out but still happened. Raised bowls to much so I now have oil that smells like gas. Should prob. change oil before I take it out again. Eric at per. Eng. will prob. senb me out a pump and filter and maybe some plugs.(hint hint if your seeing this Eric) Thanks again for advice, Been helpful........................................
SPARKS
