Old 02-25-2003, 10:46 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
It's pretty much a bolt in. You will probably need to change the main hose to the frame or adapt it. The biggest problem is the wheel offset which Dave mentioned. The rear is 1 1/2" wider so unless your wheels were set in a little they won't work. Dave also mentioned the master which would need to be changed to a 4 disc system. I use a 1976 Corvette for the 4 wheel disc. You could also adapt a master from the 96 Mustang to work. The e-brake cable from your old rear end will work.
Don
