Old 02-25-2003, 06:48 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thank you guys very much. I talked with a rear end specialist today and they're quoting a reasonable price to install a new Auborn posi unit and my choice of gearing. Since the car has always stopped just fine with the drums it might be easier to go that route. I was leaning towards the 96 rear because I was told that it already had 3.73 gears in it......today I found out that it doesn't....there's a few hundred extra $$ that I wasn't planning on.
I had 3.55 gears in it before and with a huge jump from 4th to 5th I ended up cruising at 80 and not much over 2000 RPM. I'm thinking the 3.73 or even 4.10 would be a better choice.
Thanks again for all your help!
Bill
