Old 02-26-2003, 10:54 AM
sam-tip sam-tip is offline
Smile Cutting Body
I used many tools. The body saw is the most used. Snap on part number is at190 online for 120.00. Some places you will need other tools. Sazall and jig saw work great. But in some spots you will need drimel or roto zip. Get plenty of bits. A little to much pressure and snap. I spent more time changing bits that cutting.
I also recommend round sanding disks for your drill. 1 1/4 works great for inlarging the bumperette mounts. 3/4 works great for door latch opening and finishing other openings.
My favorite is the die grinder with carbide bits and drimel fiberglass bit. It is easy to cut to much out with this tool. This tool saved me when it came to mounting the trunk and hood. I had to enlarge the bolt holes in the hinge.
Good Luck
