What do you get for the $500-?
If you get all the mounting accessories, brackets, blower pulley, crank pulley, etc, you're getting a great deal.
If it's JUST the blower, while $500- still sounds reasonable, you'll be chasing the extra parts for a while. You could buy each individual part brand new from Vortech, but the sum of the accessories would likely be more expensive than buying a complete brand new A-Trim assembly from them.
Turn the impeller inside the blower, and see if it spins nicely - doesn't make any squeaks that might prove to be a bad bearing. Remember that vortechs are gear driven inside, so you will feel the tiniest bit of resistance when you turn the impeller.
Good luck!
Craig
