Thread: TP Intake pics
Old 02-28-2003, 06:01 PM
bmalone's Avatar
bmalone bmalone is offline
Default TP Intake pics
Had the intake off the other day. So I thought I'd post some pics.
Replaced a failed head gasket and one bad valve. Also am modifying the sidepipes (went to 3" collector and racing mufflers). Jet-hot coated the headers and sidepipes (polished aluminum finish). Mostly back together--changing the pushrods and raising the rocker-arm shaft up a slight bit. Should be ready by next week.
The change to slightly longer pushrods and raising the rocker shaft is to correct what looks to be a geometry problem. Pushrods were rubbing the tunnels more than you would like and it looks like the rocker arm was contacting the shaft at too much of an angle (the whole assembly looks like it was at a slight wrong angle).
Bill Malone
Gashole
CSX4786
