Hi John Where is your battery? How many ground straps do you have going to the chassic and the motor. Make sure all your connections are tight and not corrided. My battery is in the trunk with 2 straps to the chassic and 2 straps to the motor. Run a ground strap to your voltage regulator and a good clean ground. If your alt is putting out 18.0-20.0 volts it is shorted to full output. Check the wiring on your alt to make sure the right wires are on the right terminals of the alt. I lost a regulator to a poor ground. My fault,not the cars. Hope this helps. Ck the 32 wire and the 41 black wire to ground. Rick Lake
