03-04-2003, 09:59 AM
Club Cobra Member
Fl
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Radiator & fan for Classic Roadsters
I have a brass radiator with fan and complete mounting system to fit CR Cobra. Mounted but never used. Mounting brackets are custom made stainless steel upper & lower mounting channels with 4 OEM rubber isolators. The fan is mounted to the channels with stainless steel brackets so that the fan will not touch the rad fins causing damage. To mount just drill & tap four 10-24 holes in the frame for the lower channel and attach the included "Z" bkts to the CR rad hoop. All hardware included and is stainless. The set up is good for 275 to 300 hp. $300 plus shipping. I can e-mail pictures. (mikehausner@aol.com)
