Old 03-04-2003, 01:57 PM
Ron61's Avatar
Ron61 Ron61 is offline
Unhappy
Snake,
I just got hold of Jay and then I also called another man I know that has a 460 in his Classic Roadster and the answer from them was no, they can't get the left side head off without pulling the motor. They did what I did with my stroker and set it back and that makes the head bolt hit the firewall. Eric said that if it wasn't for that head bolt hitting he could get his off by removing the steering collum. But by having them set back, no way. You might check yours and see if it is set back far enough the bolt will hit. If not then you could most likely pull the head with the motor in the car. But these are set so far back they can't even jack them up to get any clearance. Sorry.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
