Priming
I'm just a little ways behind you Randy. Just took posession of my ERA 647 and I've taken the edge off the mold seams. Needs a bunch more sanding and some epoxy filler before I even consider the primer. But I'm reading up. And I know I should put an epoxy primer on after I get it all sanded. Just not sure what type and where to find an epoxy primer.
There seem to be a multitude of "spiders" or "stars" in the gel coat. I don't think the mold was either cleaned and prepped properly or the application of the gel coat was pretty hastily done.
I thought sand blasting them to get the crud out and a good surface for bonding would be smart.
Any thoughts guys?
One other thing. What do you think about the rubberized undercoat for the wheel wells? I was thinking of keeping the bottom "clean" but coating with the clear 3M for rocker panels.
I'd like to protect the fenders though, from rocks and gravel.
any help appreciated.
Rowboy
Ziggy
