As a generalized statement from a novice.
A roller cam will allow better ramp speeds which will allow more lift and duration without the expense of larger overlap. So you get a better cam profile with better idle. Then there is the less friction advantage. As far as not using one in an FE, I don't know.
Brent Dolphin
