428 Ford Super Cobra Jet Shortblock .020" over
I have a cherry 428 SCJ shortblock, fresh bore and hone at .020" over (yes, only twenty over) with new keith black hyper pistons, reconditioned LeMans rods with new pin bushings resized big ends and new ARP bolts, has a 1UA crank STD-STD with fresh polish. Has C9ZE front counterweight. Block date code is 8K30. It has been professionally balanced with counterweighted 428 flexplate, all new parts, no expense spared and no cut corners. Block was decked square, bored, honed to fit pistons, new cam bearings and freeze plugs, we checked the main bores and they did not need to be line bored. It has Hastings moly rings. Included are the .020" over block, renewed LeMans rods, STD-STD 1UA crank, front counterweight, flexplate, new pistons, new rings, Clevite bearings, Doorman freeze plugs, Fel-Pro rear main seal kit. It is professionally balanced and assembled, comes with balance sheet. This shortblock is absolutely awesome. How many good SCJ motors are out there, much less one that is only 20 over and has a STD-STD 1UA crank? E-mail me with questions. I can e-mail you pictures if you like. You can call me at (479) 527-9166. Thank you and have a blessed day!
Randy
Randy Ritchey
Thanks for looking and have a blessed day!
"For whosoever shall call upon the name of the LORD shall be saved."
Romans 10:13
